import math
import rospy
from std_msgs.msg import Float32, UInt16
from pymavlink import mavutil
from pymavlink.quaternion import QuaternionBase
import os
import csv
import time
import random
# Global variables for roll and distance values
roll_value = 320
distance_value = 0.8
# Callback function to update roll value
def roll_callback(msg):
global roll_value
roll_value = msg.data
print("Roll value updated:", roll_value)
# Callback function to update distance value
def distance_callback(msg):
global distance_value
distance_value = msg.data
print("Distance value updated:", distance_value)
class PIDController:
def __init__(self, Kp_roll, Ki_roll, Kd_roll, Kp_pitch, Ki_pitch, Kd_pitch, setpoint_roll, setpoint_pitch, sample_time, log_folder):
# PID parameters for roll axis
self.Kp_roll = Kp_roll
self.Ki_roll = Ki_roll
self.Kd_roll = Kd_roll
self.Kp_pitch = Kp_pitch
self.Ki_pitch = Ki_pitch
self.Kd_pitch = Kd_pitch
self.setpoint_roll = setpoint_roll
self.setpoint_pitch = setpoint_pitch
self.sample_time = sample_time
self.prev_time = time.time()
self.log_folder = log_folder # Log folder path
# Initialize previous error and integral terms for roll
self.prev_error_roll = 0
self.integral_roll = 0
self.count = 0
self.prev_error_pitch = 0
self.integral_pitch = 0
# Initialize output for roll
self.output_roll = 0 # Initial output set to 1500
self.output_pitch = 0
# Create indexed CSV file for logging
self.roll_log_index = 0
def update(self, rollinput):
self.count += 1
# Compute time difference since last update
current_time = time.time()
dt = current_time - self.prev_time
print("Current time:", current_time, "Previous time:", self.prev_time)
# Check if enough time has passed for a new update
if dt >= self.sample_time:
# Compute error terms for roll axis
error_roll = self.setpoint_roll - rollinput[0]
self.integral_roll += error_roll * dt
derivative_roll = (error_roll - self.prev_error_roll) / dt
error_pitch = self.setpoint_pitch - rollinput[1]
self.integral_pitch += error_roll * dt
derivative_pitch = (error_roll - self.prev_error_pitch) / dt
# Compute PID output for roll axis
self.output_roll = (
self.Kp_roll * error_roll +
self.Ki_roll * self.integral_roll +
self.Kd_roll * derivative_roll
self.output_pitch = (
self.Kp_pitch * error_pitch +
self.Ki_pitch * self.integral_pitch +
self.Kd_pitch * derivative_pitch
self.output_pitch = int(max(-1000, min(1000, 0 - self.output_pitch)))
# Adjust output based on rollinput
if rollinput[0] == self.setpoint_roll:
print("Case 2: Roll input is 0", "Roll input:", rollinput, "Output roll:", self.output_roll)
self.output_roll = 1500
else:
print("Case 1: Roll input is not 0", "Roll input:", rollinput, "Output roll:", self.output_roll)
self.output_roll = int(max(-1000, min(1000, 0 + self.output_roll)))
# Log the data for roll
print("Count:", self.count)
self.log_data('roll', current_time, [self.output_roll, self.output_pitch], rollinput)
time.sleep(0.095)
# Update previous time and error for next iteration
self.prev_time = current_time
self.prev_error_roll = error_roll
self.prev_error_pitch = error_pitch
return [self.output_roll, self.output_pitch]
def log_data(self, axis, timestamp, output, input):
# Create folder if it doesn't exist
if not os.path.exists(self.log_folder):
os.makedirs(self.log_folder)
# Generate log file name in the format ddmmyy_hr:min:sec.csv
log_file = time.strftime("%d%m%y_%H:%M:%S") + '.csv'
log_file_path = os.path.join(self.log_folder, log_file)
with open(log_file_path, 'a', newline='') as file:
log_writer = csv.writer(file)
log_writer.writerow([timestamp, output[0], input[0], output[1], input[1]])
def set_target_depth(depth):
""" Sets the target depth while in depth-hold mode.
Uses https://mavlink.io/en/messages/common.html#SET_POSITION_TARGET_GLOBAL_INT
'depth' is technically an altitude, so set as negative meters below the surface
-> set_target_depth(-1.5) # sets target to 1.5m below the water surface.
master.mav.set_position_target_global_int_send(
int(1e3 * (time.time() - boot_time)), # ms since boot
master.target_system, master.target_component,
coordinate_frame=mavutil.mavlink.MAV_FRAME_GLOBAL_INT,
type_mask=( # ignore everything except z position
mavutil.mavlink.POSITION_TARGET_TYPEMASK_X_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_Y_IGNORE |
# DON'T mavutil.mavlink.POSITION_TARGET_TYPEMASK_Z_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_VX_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_VY_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_VZ_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_AX_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_AY_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_AZ_IGNORE |
# DON'T mavutil.mavlink.POSITION_TARGET_TYPEMASK_FORCE_SET |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_YAW_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_YAW_RATE_IGNORE
), lat_int=0, lon_int=0, alt=depth, # (x, y WGS84 frame pos - not used), z [m]
vx=0, vy=0, vz=0, # velocities in NED frame [m/s] (not used)
afx=0, afy=0, afz=0, yaw=0, yaw_rate=0
# accelerations in NED frame [N], yaw, yaw_rate
# (all not supported yet, ignored in GCS Mavlink)
def set_target_attitude(roll, pitch, yaw):
""" Sets the target attitude while in depth-hold mode.
'roll', 'pitch', and 'yaw' are angles in degrees.
master.mav.set_attitude_target_send(
# allow throttle to be controlled by depth_hold mode
mavutil.mavlink.ATTITUDE_TARGET_TYPEMASK_THROTTLE_IGNORE,
# -> attitude quaternion (w, x, y, z | zero-rotation is 1, 0, 0, 0)
QuaternionBase([math.radians(angle) for angle in (roll, pitch, yaw)]),
0, 0, 0, 0 # roll rate, pitch rate, yaw rate, thrust
def set_rc_channel_pwm(user_input,value):
if user_input == 1:
x = value # Example value for x
y = 0 # Example value for y
z = 0 # Example value for z
r = 0 # Example value for r
button = 0 # Example value for button
master.mav.manual_control_send(master.target_system, x, y, z, r)
elif user_input == 2:
x = 0 # Example value for x
y = value # Example value for y
master.mav.manual_control_send(master.target_system, x, y, z, r, button)
else:
print("Invalid input. Please enter either 1 or 2.")
master = mavutil.mavlink_connection('udpout:192.168.2.2:6900')
boot_time = time.time()
# Wait a heartbeat before sending commands
master.wait_heartbeat()
def main():
# Initialize ROS node
rospy.init_node('pid_controller_node', anonymous=True)
# Define PID parameters for roll axis
Kp_roll = 0.5
Ki_roll = 0.5
Kd_roll = 0.01
Kp_pitch = 0.5
Ki_pitch = 0.5
Kd_pitch = 0.01
# Define setpoint and sample time
setpoint_roll = 320
setpoint_pitch = 0.8
# Adjust as per your requirement
sample_time = 0.01 # 10 ms
log_folder = '/home/vyana/logs/dives/' # Log folder path
# Initialize PID controller
pid = PIDController(
log_folder=log_folder
# Subscribe to roll and distance topics
rospy.Subscriber('/nav/pixel_x', UInt16, roll_callback)
rospy.Subscriber('/nav/distance', Float32, distance_callback)
I’m running this on a Jetson nano with a real sense camera for real time detection and movement. There are no movements though the messages are being seen on MAVLink inspector. Jetson shows up as system 255. The joystick works in all 3(stabilize, manual and depth hold) modes. Tried running the code without joystick, with joystick, still no difference. Tried it in 4.1.0 and 4.1.2 versions didn’t work. Any where that I’m going wrong? Please feel free to ask for more information. Thanks.
