I was wondering if is it possible to set attitude setpoint to pixhawk with pymavlink ?
I’m trying to use the function set_attitude_target_send without any luck. I do not get any error or warning indication from pixhawk.
I’ve tried the code you gave me without luck. It does’nt seem that the blue ROV gets the yaw command.
Tried different yaw rates and thrust as well.
Any other ideas ?
You were right, works fine now.
Though other things like the simple examples from ardusub.com such as setting roll or throttle doesn’t work properly on beta
