I’m having difficulty in running my python code. Does anyone know why l lose communication everytime I run the code currently im using an Ardusub SITL simulator using the QGC. might be really helpful if you guys could help into solving this issue.
im trying to use a simple script to move the ROV foward and backwards:
from dronekit import connect, VehicleMode, LocationGlobalRelative
import time
import math
#grab distance function
from DistanceFunc import get_distance_meters
# Connect to the vehicle (replace with the appropriate connection string)
connection_string = 'udp:127.0.0.1:14550'
vehicle = connect(connection_string, wait_ready=False)
# Arm and takeoff to a specified depth
def arm_and_takeoff(depth):
print("Arming motors")
vehicle.mode = VehicleMode("STABILIZE") # Set mode to STABILIZE
vehicle.armed = True # Arm the vehicle
while not vehicle.armed:
print("Waiting for arming...")
time.sleep(1)
print("Taking off")
vehicle.simple_takeoff(depth) # Takeoff to the specified depth
# Wait until the vehicle reaches the target depth
while True:
current_depth = vehicle.location.global_relative_frame.alt
if current_depth >= depth * 0.95: # Allow for a 5% margin
print("Reached target depth")
break
time.sleep(1)
# Move forward for a given distance
def move_forward(distance):
print("Moving forward")
current_location = vehicle.location.global_relative_frame
target_location = LocationGlobalRelative(
current_location.lat + (distance / (111111.0 * math.cos(current_location.lat))),
current_location.lon,
current_location.alt
vehicle.simple_goto(target_location)
# Wait until the vehicle reaches the target location
while vehicle.mode.name == "GUIDED":
remaining_distance = get_distance_meters(vehicle.location.global_frame, target_location)
if remaining_distance <= 1:
print("Reached target location")
break
time.sleep(1)
# Move backward for a given distance
def move_backward(distance):
print("Moving backward")
current_location.lat - (distance / (111111.0 * math.cos(current_location.lat))),
break
time.sleep(1)
# Descend to a specified depth
def descend(depth):
print("Descending")
vehicle.simple_goto(vehicle.location.global_frame, depth)
if current_depth <= depth * 1.05: # Allow for a 5% margin
break
time.sleep(1)
# Ascend to the surface
def ascend():
print("Ascending")
vehicle.simple_takeoff(0) # Ascend to an altitude of 0
# Wait until the vehicle reaches the surface
while vehicle.location.global_relative_frame.alt > 0.2:
time.sleep(1)
# Main program
if __name__ == '__main__':
try:
# Arm and takeoff to a depth of 5 meters
arm_and_takeoff(5)
# Move forward
# Move forward
move_forward(10) # Move forward 10 meters
# Move backward
move_backward(5) # Move backward 5 meters
# Descend to a depth of 8 meters
descend(8)
ascend()
# Land and disarm the vehicle
print("Landing")
vehicle.mode = VehicleMode("LAND")
while vehicle.armed:
time.sleep(1)
print("Disarming")
vehicle.armed = False
except KeyboardInterrupt:
print("Keyboard interrupt detected. Stopping the script.")
finally:
# Close the connection to the vehicle
vehicle.close()
