Issue with Pan & Tilt independence on Navigator: Pan triggers Tilt and has low power
Hello everyone,
I am trying to set up a camera with an independent Pan & Tilt mount on my ROV using the Navigator flight controller, but I am running into some strange behavior that I can’t seem to resolve.
My current setup:
  • Flight Controller: Navigator
  • Camera Mount: MNT1_TYPE is set to 1 (Servo).
  • Tilt Servo: Assigned to Channel 16.
  • Pan Servo: Assigned to Channel 10.
The issues:
  1. The Tilt axis works perfectly fine and accepts independent commands without any problem.
  2. However, the Pan axis is not independent. Whenever I try to move the Pan servo, the Tilt servo moves along with it simultaneously.
  3. Additionally, the Pan servo seems to be visibly weaker and has very low power/torque compared to the Tilt servo.
I am completely sure this might be a configuration crossover or a power issue, but I haven’t been able to separate the Pan from the Tilt.
Has anyone experienced this specific behavior with the Navigator? Could this be a software mapping conflict in ArduSub/Cockpit, or does it sound more like a hardware/voltage drop issue affecting the PWM signal (3.3V logic level) when the Pan operates?
Any guidance or troubleshooting steps would be greatly appreciated!
Hi @ATLASUBSEA -
Can you share what you have set the servo_funciton_10 to? Is this mnt1_yaw?
Sharing a .BIN log would be helpful in assisting you - you can find this under autopilot logs - arm the vehicle, test your servo functionality , disarm, download and send the log file.
It should be possible to operate the two servos independently!
