Thanks @williangalvani for tip!
I took a journey in the pymavlink world and made a script to disable Roll and Pitch on BR2 6DOF.
One usage is when piloting close to silty bottoms, You do not want vertical thruster blows.
In case somebody want to use, I put modules at Github: GitHub - BoKoppel/BlueROV2: BlueROV modules.
Found two small issues in the site that helped me scripting: Pymavlink · GitBook
Info on Ardusub site: # Set parameter value # Set a parameter value TEMPORARILY to RAM. It will be reset to default on system reboot.
After setting parameter values to 0, they do not go to default after reboot.
I solved that by making 2 scripts: StabOff.py that sets Roll and Pitch off, StabOn.py that sets parameters back to original.
