I was keen to take a look at how the ArduSub development was progressing, but keep hitting this error when compiling:
fatal: reference is not a tree: 3b960549601cc22b7bbaa89257833f8d9053e491
Unable to checkout ‘3b960549601cc22b7bbaa89257833f8d9053e491’ in submodule path ‘…/modules/PX4Firmware’
Sorry, I made a mistake in a commit this morning which broke the submodule in git. Rusty or I will let you know when this is resolved, I’m looking into it now.
Might be a bit off topic now, but what’s the standard approach to teleoperating the PixHawk running ArduSub?
Are you running a RPi as a companion computer, connected to the PixHawk via mavlink, with Mavros providing the link back to the surface computer and joystick? Or something simpler?
That is how I do it. Rusty has been using qgroundcontrol to send the joystick commands to the pixhawk. Rusty’s approach doesn’t require a RPi or ros, and is easier to set up/run. I use the approach you mentioned because my tether is an ethernet cable, which obviously won’t plug in to the pixhawk.
To use Rusty’s approach, you will need to download a daily build of qgc.
To use my approach, you will need to start mavros with this command, instead of using the apm.launch file in the bluerov ros package.
Great, I haven’t tested the pixhawk in the water with this method, but indications on my desk are that it is working. I will let you know when I have put it in the water. This is still a work in progress.
Also the controls with my Hexa branch are different:
Left stick: forward and yaw
Right stick: roll and pitch (disabled at the moment)
Scratch that, disarming does not work right now, I would not try to use this while the pixhawk is connected to motors. I’ll update you when it’s sorted.
There is still some work to be done using ros with the pixhawk. I had it running well with the apm, but upon closer inspection, I am seeing some issues on the pixhawk that will need to be worked out. I have fixed the arming issue, but inputs are being dropped unless they are constantly changing.
Andrew, I have finally performed several test flights with the pixhawk on the BlueROV. You should pull the changes made in ArduSub over the last few days into your local repository. The pixhawk requires some changes to PID coefficients to perform optimally. I am still fine tuning those parameters, they will go up when I am finished. I am interested in hearing how your tests go and where you are at with this, as well as any feedback.
I’ll pull down the latest changes and let you know how things go.
I’m running a little behind where I wanted to be with the build, so still running bench tests. My custom frame is complete, just waiting for my thrusters to arrive then I can get it into the pool for testing and tuning.
I experimented with a few connection setup options last night to see how they’d work. Using qgroundcontrol on a laptop, connected to a RPi running Mavproxy, with the RPi connected to the Pixhawk running Ardusub via serial seems to work well and integrates the RPi video stream directly into the qgroundcontrol hud.
So I think I’ll run my first pool tests with that setup once the thrusters arrive (hopefully in the next couple of days).
where XXX.XXX.XXX.XXX is the ip address of the laptop where qgroundcontrol is running.
The other important step is to make sure you’re running a version of qgroundcontrol that supports video streaming - the pre-compiled versions don’t seem to so I’ve installed the development build from here:
I’ve found the video window in qgc. It says no video, though. I am connected to the pixhawk via raspberry pi, and raspicam is running. Do you have to create an additional comm link in qgc for the video feed? Or do you need to run an additional terminal command on the laptop to start the feed?
No additional comm link is needed in qgc so long as the right target ip address is in the rpi command block. I’ll double check I haven’t missed any steps in the notes above when I get back from work later today.
