Regarding your question im afraid that its been so long since I tinkered with it last that I have forgotten - ive tried to find out but with no luck
Ive been trying your suggestion and following in order is what I have done so far :
Installed Qground Control v.3.2.4 Rev6
Connected the Pixhawk via ethernet cable
Updated the firmware
Setup Controls
– Here is my problem so far : The controls are way too sensitive - it almost feels like a switch turning on or off. Qground control I can see the control bars rise as I use the analogs.
Question : Is it possible to configure the sensitivity on the controls within QGround Control or even through software or do I some sort of controller for this adjustment
You can assign joystick buttons to change the input gain to the ROV. Take a look here. Specifically at “gain_inc” and “gain_dec”.
Also make sure your joystick is not one of those with the “analog” button. Those can change between digital/analog modes, and digital mode will be all or nothing, jumping instantly from the center to the edges.
