Hi, I’m trying to figure out what parameter values are used in the firmware images, and I was hoping to find the script(s) used to build the images so that I can follow the steps exactly. Is there a repo somewhere that I’m missing?
I’ve been using these commands to learn ArduSub, and they work great:
$ ./waf configure --board Pixhawk1
$ ./waf sub
BUILD SUMMARY
Build directory: /home/clyde/projects/bluerov2_ignition/ardupilot/build/Pixhawk1
Target Text (B) Data (B) BSS (B) Total Flash Used (B) Free Flash (B)
bin/ardusub 1336548 1832 194980 1338380 742376
I suppose the parameters are just the defaults from the various locations in the code. But then I came across these param files and I thought I should try to build with these instead – to make sure that I’m getting the exact same parameters. But I can’t seem to get those to work:
$ ./waf configure --board Pixhawk1 --default-parameters=Tools/Frame_params/Sub/bluerov2-4_0_0.params
$ ./waf sub
Broken revdeps detected on {
{task 140040649966864: generate_bin ardusub -> ardusub.bin},
{task 140040649967200: build_intel_hex ardusub.bin,Pixhawk1_bl.bin -> ardusub.hex},
{task 140040649966976: generate_apj ardusub.bin -> ardusub.apj},
{task 140040649967088: build_normalized_bins ardusub.bin -> }}
Any advice?
Thanks in advance,
/Clyde
