Parameters are missing from firmware error
I am starting a build I have a windows 10 PC running QGroundControl v4.1.1, a Raspberry PI with the the companion image v0.0.25 and a Pixhawk 2.4.8 with the Ardusub v4.0.2.
I constantly get the error " Parameters are missing from the firmware. You may be running a version of firmware which is not fully supported or your firmware has a bug in it> Missing params: 1:r.BATT_FS_LOW_ACT, 1:r.BATT_FS_LOW_VOLT, 1:r.BATT_FS_LOW_MAH"
Is there something I am missing or should I be running another version of the firmware?
Hi @Paul_461,
This is a bug. The parameters at not exposed by the firmware until you setup the power module.
Go to the power tab to set it up and the warning will go away:
