Thruster stalling and not relaunching
I am kinda stuck here, coming from Quads i know the Basics about ESC Config etc. but i dont get the T200 R1 Thrusters to work reliably.
I have used the default BLHeli32 Setting with LOW RPM Protection off but sometimes a Motor did stall somehow. I found the BLHeli Config file here in the Forum but i got a lot worse. I played with some settings but no success. I am using Tekko32 ESCs, is there something special about the BR ESC?
I will attach a short video where you can see and hear the stall. Listen carefully to the motor after i release the throttle and zoom in on the Motor itself, it makes a buzzing sound even without throttle. Just after turning it about 1/2 round it stops and spins freely again.
Any help is appreciated. Thanks!
Hi @rico, welcome to the forum :slight_smile:
Hopefully one or both of those is helpful?
Not that much since I am using this already. What about the commutation timing, you recommend 3°, really this low?
Hi @rico,
Not sure what’s going on here, but it may be an ESC firmware issue. Try loading the analogous settings as we use on the BasicESC to your ESC:
Note that “Medium” timing in BlHeli_S corresponds to 15°.
-Adam
Thanks a lot! I just dumped your config into BLHELI32 Suite but it does not interpret the values correct.
I did test yesterday with an Throttle Increase Limit rate of 1%/ms and it worked fine. I will test the correct settings you posted today and will upload the results.
