Hi I have a brand new T200 which was working perfectly for a day during out of water bench tests and suddenly became extremely slow. During bench tests I only ran the motor at 5 -10% throttle and only for under 5 seconds at a time. I´m using a 12v lithium battery to a ZTW 50a ESC to the T200. I tried running it under water to see if that would stabilize it´s performance somehow but no luck.
Hi @asherisaac,
If your ESC has any settings along the lines of “low RPM power protect” and “demag compensation”, you will need to turn those off to properly run a low Kv motor like the T200.
Our thrusters should not be run dry in air, its possible something may have been damaged if it no longer spins feely by hand.
-Adam
Hey Adam thanks for the quick response. I switched inputs on my flight controller and it works great again. Not sure what happened. I should have tried that before posting here.
