when using the blue robotics T200 thrusters with the Speedybee BLS 35A Mini V2 20x20 4 in 1 ESC(SpeedyBee F405 Mini BLS 35A 20x20 Stack - Speedy Bee), the T200s just twitch and draw almost exactly 1 amp, the T100s work as intended when connected to the same ESCs, and the T200s used for testing worked as intended before and after with blue robotics basic ESCs.
does anyone have ideas for alternative to the Speedybee 4 in 1 ESCs or why the T200s are not working properly with these ESCs?
Hi @teddyA
Welcome to the forums!
Since the motor functions fine with another ESC, the issue is likely with it. I’d suspect a bad motor phase wire connection, or some configuration settings not looking the low kv of the motor. This is unlikely- that ESC is perhaps just damaged- does it work with other brushless motors?
