Set static IP for Ping 360
We recently buy a ping 360.
How to use it over ethernet with a different IP adress? We would like to set it ot 192.168.1.?
Regards,
Yes, check it here:
I’ve been able to connect to the ping sonar via UDP.
How ever the IP adress is 169.254.209.14. There is no icon for changing it.
How can I manage to change the adress?
Regards,
Hi @achat,
As you can see from my previous link, this is only available on the daily build, not an official release, you can check more about it here:
https://docs.bluerobotics.com/ping-viewer/build-instructions/#daily-builds
Thanks! Everything is working
