Heyo,
I’m calibrating my BlueBoat compass in Qgroundcontrol, and after scouring the forums for solutions keep running into a PreArm: Compasses inconsistent error!
I’m doing the calibration in a soccer field so it cant be interference?? Compass 1 (IST8308 (I2C6)), and Compass 2 (MMC5883 (SPI1)), are in green, but Compass 3 (AK09915 (I2C1)), is always mid yellow after the calibration. The actual location in Qground control is accurate to within a few meters when I see the blueboat on the main page but I always have the error. I have tried to deselect use of the compass, but to no avail.
I have autopilot rotation set to Roll 180, and have compass 1 (external) set to pitch 180 as is in the guide. However I have played around with the orientation of compass 3 (which doesn’t have an orientation option in the guide? and is also an external compass) from roll 180, pitch 180, or none.
Still getting the same issues…I’ve found that it may be caused by the internal and external compasses pointing in the wrong directions? so hoping someone has had this issue and can help, and that its just a matter of selecting a different orientation from the drop down??
Also running ardupilot firmware version 4.5.1 (stable), and OS version 1.2.5 if those might be causing issues?
Cheers
Alex
