Hi.
Just recived my BlueBoat.
The Navigation ligth stopped bliniking when i updated the firmware 4.5.1 and blueOS 1.2.2
Also it says in QGS that radio needs to be calibrated before use of the boat.
I managed to calibrate the Accelerometer and compass. but in the manual it says to check direction on truster in the motor page on channel C and D but mine are on channel A and B
What is wrong here. I checked wiring diagram and it is on channel 1 and 3 as stated
Hi @Pezman -
You can ignore the radio calibration in QGround Control, this is only necessary if you’re using an RC radio/receiver in conjunction with your BlueBoat.
To get the light blinking again, and potentially corret the AB/CD channel issue, please re-run the vehicle setup wizard and select the parameters file for BlueBoat. You can find this option at the bottom of the left menu in BlueOS, under the settings gear.
@tony-white
Yes, it has been connected to internet through wifi during the wizard. But it says there is no parameter
I’ll try and update the blueOS and rerun the wizard
