Hello, I have a problem with the equipment, it is simply not responding correctly to the commands of the controls, of the 6 thrusters, two work in the opposite order…
was not dismantled
was not rescheduled
checked the QGC settings, and nothing was found
Was the initial problem fixed by the automatic motor direction detection, or was your follow-up comment intended to provide additional explanation of what’s going wrong (or perhaps a description of a new, different problem)?
If the problem is fixed but you were providing extra context to try to understand why it happened to start with, I expect there would have been a parameter reset or something which changed the motor direction parameters to different values.
The equipment just stopped responding, I don’t know the cause, but apparently some parameters are wrong… I did a restoration using QgraundControl itself and now, two impellers rotate in the opposite direction, I’m trying to solve it but I can’t
Have you tried the motor configuration instructions I linked to? The automatic configuration should be able to detect and resolve this issue.
By the way, which QGroundControl version are you using? You may also need to re-calibrate your joystick, in case the issue is from that rather than actually being related to the individual motors.
