Problem with the ardusub-raspbian.img.gz
Hi
Dose anyone know if this image works for raspberry B+ .
The raspberry is not booting with the latest image rasbian-ardusub(1.47 GB, Updated 2016-10-19)
I am getting this code from my terminal:
dd: /dev/rdisk2: Invalid argument
1406+1 records in
1406+0 records out
1474297856 bytes transferred in 21.832982 secs (67526179 bytes/sec)
the Raspbian Jessie Lite image instead booting as normal
Thanks for your help
George
Hi George,
The image we have is set up for the Raspberry Pi 3. I don’t think it will work on earlier versions. However, you can start with a plain Raspbian Jessie Lite image and follow the instructions here to set it up manually: http://ardusub.com/raspi-setup/#setup-from-scratch
I hope that helps!
Thanks a lot for your fast replay
I changed the microsd card .Now the raspberry booting with the latest ardusub image .
I will test later today if everything working with the rov
Regards
George
George,
Oh good! Please note that the SD card has to be 8GB or larger for our image to work.
Hi Again
Raspberry all good , streaming video connected via Ethernet on a mac trough QGC but not on windows 7 ,firewall disable
any thoughts .
Regards George
Hi George,
Make sure the subnet mask is set to 255.255.255.0 and IP address to 192.168.2.1 for the host computer.
Can you verify that all that is set properly?
Hi
I have checked I get connected with the QCG but not picture in windows 7 still .On my mac no problem everything runs well .Ready to do a water test .Can you confirm that windows 10 working .In order to upgrade
Regards
George
George,
Okay, the video definitely works well in Windows 10. We’ve had mixed results with Windows 7 and haven’t nailed down a solution yet.
Hi
Yes the video working on windows 10 .No problem
Thanks a lot
