Problem with camera tilt
Dear BlueRobotics
I hope you can help me wiith a problem. I have connected the camera tilt servo to channel 8 on the Pix. The lights are connected to channel 7.
I can turn up the lights with the correct buttons on the controller. But the camera tilt system wont move.
Do I need to program something on the Pix to get it to work?
Hope you can help
All the best
Per
Did this get sorted out?
If not, have you made sure that you’ve plugged the camera tilt servo into the same port as the one you’ve set in QGC?
