when connect all pins to pixhawk , 7 and 8 pins not working
Hi @vugarccc -
Are you trying to upgrade from standard frame to Heavy? You will need to change the frame type to activate channels 7 & 8 for control of the additional thrusters…are you following the documentation here?
i am using heavy but not working
Hi @vugarccc,
It is difficult for us to help you when we don’t know what you have tried so far, and how things are going wrong.
As some points to clarify:
- How have you determined that those pins are not working?
- Have you checked the
SERVO_OUTPUT_RAW
MAVLink message contents? - Have you checked the pin signals with an oscilloscope, or connected them to known working ESCs and thrusters?
- Have you done the relevant software setup?
- I recommend checking the
SERVO7_FUNCTION
andSERVO8_FUNCTION
parameters to see whether they are correctly set toMotor7
andMotor8
