NTRIP Extension Decoding Error
I’m currently attempting to set up a simpleRTK2B Budget to receive NTRIP corrections using the NTRIP extension on BlueOS. When I attempt to connect, I receive the error below:
The RTK module is currently connected to the Blueboat navigator board via Serial3. I’ve changed the protocol used on this port but the error persists. Any insight into what might be causing this would be much appreciated, thanks.
Hi @JColumb -
Welcome to the forums!
What RTK module do you have connected to the BlueBoat? Typically it would occupy two serial ports if you have two receivers?
The error there looks more to do with how you’ve configured your connection to the correction service extension, than an issue with the GPS… you should get position working first - that ensures the autopilot is correctly communicating with the GPS.
Have you successfully used the RTK GPS? If you run a newer version of QGIS, and have a base-station GPS connected to your computer, it should send local corrections…
Sharing your autopilot parameters would help.
Hi @tony-white,
Thanks for your reply.
Turns out the NTRIP extension was the issue. I uninstalled it and installed the previous version which seemed to fix the issue.
