Looking to get NTRIP running (migrating to BlueOS, hw/sw working fine previously)
Installed the NTRIP extension via the extension manager, tried both v0.3 and 0.2, installed easily
Connected to ip:8000 with ip being that of the Pi with BlueOS on it, and got the worlds smallest web page, and nothing further (both chrome and firefox). What am i missing ? Thanks in advance
The NTRIP extension should create a menu entry on the left side of BlueOS once it starts up. From there, you can configure it to use your desired rtk2go correction source. If you have compatible RTK GPS connected to the autopilot, the corrections should be received and applied, and you’ll see the GPS lock type change (on the GPS icons in the upper right of BlueOS.) If you’re having issues getting the extension to load, please share logs found on the installed extensions tab > view logs > download
Thanks - it was as you said - up and running, having installed successfully and now on the left hand list. I typed in my rtk2g0.com connection string and it fired up immediately - call that perfect. Many thanks, and apols for me missing it
