hello, I have my ROV connected to laptop running windows 10. I connect thru QGroundcontrol. I can control thrusters and lights but I am not getting any video. I have the standard electronics package. HELP!!!
Hi Eddie,
Thats right, the “Standard” electronics sends video topside as a composite NTSC signal. You will need to connect either:
- A video monitor (NTSC), or
- A video capture board (which will convert the composite video signal to display on a computer)
to the RCA connector on the topside board.
I have a video monitor hooked up with the yellow lead of a composite video cable to the top-side box and to the video monitor. I have the video monitor on audio video input. getting no signal.
I would double check your wiring. Also verify that whatever monitor you are using works with a composite NTSC signal.
Hi Eddie,
Could you share a few pictures of how you have things connected up? That would be really helpful.
I changed monitors and it works fine. The monitor is new so maybe there is a setting I am missing. Thanks
