Trying to update all the software above link is down is there a alternative to use?
Bill
Bill
Hi @RogueWave
192.168.2.2:2770/system gives you access to the Companion Web Interface through the local network. If you can’t access this page then there is probably something wrong with your network settings. Try the troubleshooting steps here: Redirecting...
I do not get a ping return… ipconfig is fine
Hello Daniel:
ipconfig is fine but I do not get a ping return …It was working a day ago… trying to update all software. I did the pi one then this happened no connection //192 etc…
Bill
will be away from computer for couple of hours 4:35 EST
Found problem user mistake I am continue software upgrade.
