Issue integration water-linked with A1 to Blue ROV network bridge
Hi Iv’e tried multiple integration paths (integration kit and network bridge) and still no luck getting waterlinked or qgroundcontrol to pick up our A1 locator or position, currently trying the network bridge approach but when I create it the ROV loses connection with ground control.
Any pointers would be fantastic!
Hi!
Start with network checking.
Try to ping ROV/Companion:192.168.2.2, Waterlinked box 192.168.2.94
If that do not work, probably cause is network setup hard- or softwarewise.
You have to be on same network with all equipment, normal or bridged.
Next is to check Waterlinked UI: http://192.168.2.94
Check in diagnostic page
Check Companion Waterlinked service status: http://192.168.2.2:2770/waterlinked
