My network bridge is setup properly (IP: 192.168.2.1, Mask: 255.255.255.0). I’m connecting to the Underwater GPS via wifi with the IP switch set to the static 192.168.2.94. Pinging 192.168.2.94 through 192.168.2.2:8088 returns “PING 192.168.2.94 (192.168.2.94) 56(84) bytes of data” with no response or prompt for another input. The waterlinked section of the ArduSub companion lists the status as “scanning for Water Linked underwater GPS”.
I do not use wifi, but I think Waterlinked has a different IP range for the wireless.
Check that wifi adress in Waterlinked is possible to set to 192.168.1.94.
That means you have to disable the wired network in Waterlinked.
If that is not possible, you have to work with wired network, or at least wired network from Waterlinked to your own wifi router. From that router you might connect Waterlinked from ROV.
Safest is wired connections…
