No, still the same.
Looks like this is not ment to be… ![]()
Any other setup data I ned to add?
Do I have to make any changes in the ArduSub setup?
Thanks for your assistance.
Reg.
Bjarte Røksund
No, still the same.
Reg.
Bjarte Røksund
Do yo have the default setup of ArduSub? If so the IP should work.
When you set up the IP of the adapter on the iPad dont forget the mask 255.255.255.0, gateway you do not enter
after that please restart both rov and iPad
you should also be able to go to safari on ipad and open rov settings:
http://192.168.2.2:2770/
I’ll tryvsome more ![]()
Mvh
Bjarte Røksund
@Roksund if this (the Companion Web Interface) works, there may be some connection issue between the Pixhawk autopilot board and the Raspberry Pi computer, in which case you might want to go through our troubleshooting steps (several of them should still apply, just not the QGroundControl ones).
YES! I finally made it. It is up and working now. It was the gateway input that was the missing link. Thanks for all the good help and assistance from you guys, I really appreciate it!
best regards
BR
Just tried the iPad app and after a bit of fiddeling around I got to work (partly by using this forum where I`m new) However the Newton Gripper only work when the Xbox controller is disconnected (then the on-screen buttons appear on the left of the sceen) But without controller you can’t drive the ROV. And I do not get any options for asigning the gripper to the controller-buttons.
Is there a way of fixing this?
(Using Sublutions RespondROV to FXTI to Apple camera dongle to iPad Air3 with separate power to the FXTI)
[quote=“Giuseppe Costantino, post:28, topic:10224, full:true, username:kostantin”]
Tested all OK with a random IPAD 6th gen. Some tweaking on the wifi address and connects pretty easy.
