The problem is that i am not able to set up my gimbal for my camera on my ROV. on my computer, when i go to the camera tab in the vehicle setup column, i do not see the gimbal settings, angle set points or the stabilize feature. i knew it was supposed to have it because in the ardusub documentation for setting up the gimbal, it had those features. (you can see that in bullet #1 below). i assume that this this the main problem for why i am not able to control my gimbal servo. Another thing i should also put out is that i was not able to download the Blue ROV2 Parameters on to QGC so that could also be a reason why. Big thanks to everybody helping
all i want to do is to control an underwater servo with buttons on my joystick but i dont see any parameters that fit that descriptions. i am 3d printing a gripper claw so i can pick stuff and move them around underwater. it is actually for the MATE competition so is there a way to hold a button on my controller to open and close it.
You can use as many servos as there are available slots.
What is your goal?
Your questions are not very clear, so I don’t understand what you want to know.
I am sorry for my english.
I want to 5 servos control and 1 lights control in pixhawk.And I can only use gimball tilt.I tried gimball pan but servo is not work.
Thank you.
I want to use to 1 servo for camera, 4 servo for gripper(2 servo up and down,1 servo for open and close,1 servo for turning).My main out is full.So I use to 8 motors.
I was understand your answer but how can I use to 5 servo?
