Hi @cbusse1 ,
Thank you for your investigation! Did you actually try any of these changes?
The integrator reset was removed to fix the depth hold bounce-back issue: AC_PosControl_Sub: do not reset accel_z integrator when relaxing by Williangalvani · Pull Request #12952 · ArduPilot/ardupilot · GitHub
Apparently it resulted is this other issue. The integrator shouldn’t be touched in manual/stabilize, which is why I suspect this is to blame:
This is called every time the controller is initialized, which includes mode changes.
Do you still have the .bin log for these plots? I’m wondering if the mode change coincides with the jump in the integrator.
