Bonsoir à tout le monde.
je voudrais de l’aide s’il vous plaît.
je dispose d’un sonar ping2 pour un projet.
pour voir si il fonctionne , j’ai essayé de la connecté à mon Pc à l’aide de l’adoptateur USB-Série.
je suis ensuite allé sur pingreview, mais j’ai constaté que la connexion n’est pas établi avec le PC.
le choix des ports ne m’est même pas offert quand je sélectionne la communication série.
Hi @Mobosy -
I translated your post as:
Good evening everyone.
I would like some help please.
I have a ping2 sonar for a project.
To see if it works, I tried connecting it to my PC using the USB-Serial adopter.
I then went to pingreview, but I noticed that the connection is not established with the PC.
the choice of ports is not even offered to me when I select serial communication.
Does your computer recognize your USB serial adapter? This should show up in the Windows Device manager as a comm port - if not you may need to install the correct drivers?
Do you observe any blinking lights on the adapter that indicate communications traffic?
Thank you for your answer. But I don’t see any light. In device management too, I don’t see anything that indicates that there is a missing driver.
My computer runs Windows 11
Thanks in advance for your answers
Hi -
Do you see a comm port appear in device manager when you connect your serial to USB adapter? Something like this?
I don’t see this port on my device manager
