Connect a Hemisphere GPS to QGC, is it possible?
Is it possible to enter coordinates of a Hemisphere GPS connected to a serial port of the computer and be able to see it in the Overlay of the navigation screen?
Hi!
You have to send NMEA sentences GGA to 192.168.2.2:27000 by UDP.
That means you have to use a program to listen to serial port and resend by UDP:
Note that it is topside position you send by doing this way, not the Sub position.
After having this work you can setup QGC to display lat and long.
Thank you very much, you have solved the problem for me!
Hello again BO,
I have a problem with the NMEA input for positioning, in the NMEA Router it works for me, but in the QGC it does not recognize it, I don’t know if it is due to the new version of L QG, could you help me?
Thank you!
Hi!
Are you connected to the ROV?
The NMEA sentences to QGC goes via Companion and Pixhawk.
Check the status in companion http://192.168.2.2:2770/
If you are using the new Blue OS and not companion; I have not tested that setup for positioning.
Yes yes, it is connected to the ROV, I have looked at everything on the BLUE OS, I don’t know what to do anymore… there is something that escapes me.
I usually use Companion, try the last working versions you had last time.
Or try to get support on BlueOS from Bluerobotics.
