I need to change the IP address for the companion computer in order to work around some firewall issues (disabling or adding exceptions is not an option). I changed the address for the computer and I am able to access it either via ssh or the web UI but I am having issues with QGroundControl. I confirmed using a different machine that everything connects fine with the original IP address.
I looked through the code and saw that the computer IP appears to be coded into a few places in some of the parameter files. I adjusted the IP addresses and was able to see the camera via QGroundControl. I am still not able to see anything from the Pixhawk. I ran screen -r mavproxy and it is definitely running.
The param files I changed are gstreamer, gstreamer2, and mavproxy. For mavproxy, I changed the final number for udpbcast to 20 rather than 255 since that value isn’t available to me. Is this supposed to match to the MAVLink System ID in QGroundControl? I tried changing that value but it is still not connecting.
Am I missing any other parameter files or other places where I need to update an IP?
Thank you.
