I’ve been running my ROV without any problems for a while now. However. I decided to change the IP of the RPI (and PC) to 192.168.1.x to make it compatible with an ethernet sonar I’m using. When I changed the IP, Qgroundcontrol no longer connects to the pixhawk.
I can still use the web interface for the RPI and once I changed the host ip for the video to the new IP address it works and shows up in Qgroundcontrol.
I’ve tried the troubleshooting on the homepage but nothing helps. I can see the pixhawk and software version through the RPI web ui. It just doesn’t want to connect via Qgroundcontrol.
So, this happened due to a change of IP on the RPI and PC. Nothing else.
The companion software is hardcoded to send telemetry to 192.168.2.1, your computer is not on this ip, so it cannot receive anything.
You can change the ip address at 192.168.2.2:2770/mavproxy and 192.168.2.2:2770/camera, or wait until dhcp is supported (scheduled by/before jan 1 2020).
The ROV computer is configured to send telemetry to 192.168.1.2 by default. It is possible to change it as described above, but we do not support any other configuration at this time.
