Hi!
I can’t connect to my companion rPI from my surface computer via Wi-Fi. I tried with notebook and phone as well, but I got only “Disconnected” message in QGroundControl’s headline.
Here are the log messages what I got from the surface computer’s QGroundControl:
[D] at D:\a\qgroundcontrol\qgroundcontrol\src\QGCApplication.cc:281 - "Settings location "C:/Users/Me/AppData/Roaming/QGroundControl.org/QGroundControl.ini" Is writable?: true"
[D] at D:\a\qgroundcontrol\qgroundcontrol\src\QGCLoggingCategory.cc:120 - "Filter rules "*Log.debug=false\nRTKGPSLog.debug=true\nGStreamerAPILog.debug=true\nqt.qml.connections=false""
[D] at D:\a\qgroundcontrol\qgroundcontrol\src\QGCApplication.cc:384 - "System reported locale: QLocale(English, Latin, United States) ; Name "en_US" ; Preffered (used in maps): "en-US""
[E] at :0 - "serialnmea: No known GPS device found. Specify the COM port via QT_NMEA_SERIAL_PORT."
[E] at D:\a\qgroundcontrol\qgroundcontrol\src\PositionManager\PositionManager.cpp:188 - "QGCPositionManager error 0"
[E] at :0 - "Location access failed."
[D] at D:\a\qgroundcontrol\qgroundcontrol\src\Vehicle\MAVLinkLogManager.cc:360 - "MAVLink logs directory: "C:/Users/Me/Documents/QGroundControl/Logs""
[D] at D:\a\qgroundcontrol\qgroundcontrol\src\QtLocationPlugin\QGCMapEngine.cpp:164 - "Map Cache in: "C:/Users/Me/AppData/Local/cache/QGCMapCache300" / "qgcMapCache.db""
[D] at qrc:/qml/MainRootWindow.qml:51 - "QGCCorePlugin(0x18a7b9f5830) []"
[D] at D:\a\qgroundcontrol\qgroundcontrol\src\MissionManager\MissionController.cc:2371 - "setCurrentPlanViewSeqNum"
[D] at D:\a\qgroundcontrol\qgroundcontrol\src\QGCApplication.cc:860 - "Download QGC stable version failed "Error during download. Error: 3""
[D] at D:\a\qgroundcontrol\qgroundcontrol\src\MissionManager\MissionController.cc:1272 - "_recalcFlightPathSegments homePositionValid false"
But I can ping the companion from the phone and from the computer as well (not the same time, of course).
Here is what i see on phone, and the ping with termux:
And here is what I got on computer:
