Hello, I have a problem and I can’t find the solution. When I’m in the cockpit navigating manually, and I tilt the rudder forward, the camera tends to stabilize until the value stays at 0. Can this be canceled? Can I make the camera not stabilize and stay at the same angle as when I put it in manual?
Thanks.
Hi @marctosas, welcome to the forum ![]()
This is an autopilot configuration, and is unrelated to Cockpit. You can disable automatic gimbal stabilisation in BlueOS (in Vehicle Setup > Configure > Camera Gimbal), by turning off the “Stabilize mount” option[1].
Hi Elliot,
Thank you! I’ll try asap.
