Hi people. My camera seems to be mounted correctly to the tilt servo motor - when the camera hits the mechanical limit it’s vertical. In reality the view when at the lower limit is about 60 degrees and the image is of the inside of the electronics tube, but the upper limit is only about 45 degrees. Is there a way to adjust the tilt limits in QGC? Thanks!
you can change the degree in qgroundcontrol camera setting
Thanks for the tip sunnyroover. I check out the cam settings and didn’t think that tilt limits were an option. Is it one of the parameters in this image?
Thanks Jacob - that did the trick.
