BR2 USB camera -more tilt?
Hiya, is there a way to increase the camera tilt range? I realize that this is not really a camera issue but the tilt mechanism and control. 90 degrees is not enough.
Hi @salvor1,
It hasn’t been documented properly yet, but I recently found that the servo in our Camera Tilt System actually supports from 750 to 2250us, which you can set/enable in the Camera Mount Setup Page of QGroundControl :slight_smile:
Note that if it tilts too far the camera cable may get pulled, which could cause issues with the stream.
wow, thanks, I’ll check it out.
