Just turned on the rov 2 today and for some reason the camera is not operation the same. Yesterday pan up and down worked perfectly today it will only pan up or down as long as I hold the pan buttons. Once released it automatically return to the home /level position.
This has to do with the version of QGC that you are using, like your other post. Please make sure you are using the version that we directed you to. Then click the gears icon to get to the Vehicle Setup page, and adjust the mount tilt speed on the Camera tab to fix the problem.
