Blueprint subsea SeaTrac USBL integration (Python)
I’ve been experimenting with a Blueprint subsea SeaTrac X150 and X110 USBL (underwater GPS). Thought I’d like to share what I did to use it with the BlueROV2.
Set-up:
  • SeaTrac X110 and battery mounted on the BlueROV2
  • SeaTrac X150 mounted on the boat / base station and connected to the PC
  • USB GPS connected to the PC
  • Of course, ROV tether connected to the PC
Using the supplied software, I checked the beacon configuration. Not sure if it is needed as the blinking of the LED tells the beacon ID (3 in my case). You can also adjust for salinity etc.
As the supplied software is a bit cumbersome and not really reliable (and runs on Windows), I wrote a Python script (runs on Linux) that computes the position of the ROV and sends it as a NMEA string to the raspberry pi using UDP on port 27000. It also stores the position history in a .csv file.
As the boat provides GPS data over WiFi, we can choose between a USB GPS and the GPS on WiFi (Yacht Devices WiFi Gateway)
This script works in Switzerland as it is based on the CH1903 coordinate system. I guess it’ll also work in the neighboring countries.
I used this library for converting the coordinates: wgs84_ch1903.py. You should put it in a subfolder called “lib” along with an empty file called “__init__.py”.
import socket # GPS and ROV, TCP/UDP
import serial # SeaTrac
import serial.tools.list_ports
import crcmod # SeaTrac checksum
import select # Non-blocking communication
import pynmea2 # NMEA
import lib.wgs84_ch1903 as wgs84_ch1903 # Swiss coordinates
import datetime # Time of day
import time # Program time
import csv # Write to csv file
# Parameters
# CSV file location
csv_filename = "ROV.csv"
# Set to false to use the boat GPS information (Yacht Devices)
USE_SERIAL_GPS = True
# Yacht devices address
GPS_IP = '192.168.178.9'
GPS_PORT = 1456
BUFFER_SIZE = 4096
# ROV address (UDP)
ROV_IP = '192.168.2.2'
ROV_PORT = 27000
# ROV position update interval
ROV_UPDATE_SECONDS = 0.5
# SeaTrac baudrate
SEATRAC_BPS = 115200
# SeaTrac ping interval
SEATRAC_PING_SECONDS = 3
# Global variables
gps_wgs84 = { 'lat' : 0, 'lon' : 0 }
gps_swiss = {   'x' : 0,   'y' : 0 }
gps_lastfix = ''
rov_depth = 0
rov_swiss = {   'x' : 0,   'y' : 0 }
rov_wgs84 = { 'lat' : 0, 'lon' : 0 }
# SeaTrac serial port setup
# Display all serial ports
ports = list( serial.tools.list_ports.comports() )
print( "Serial ports:" )
port_id = 0
for port in ports :
	print( "{}: {}".format(port_id, port.device) )
	port_id = port_id + 1
# Ask the user which port to use
while True:
	user_selection = input("\r\nSelect SeaTrac serial port: ")
	if user_selection.isdigit():
		user_selection = int( user_selection )
		if user_selection >= 0 and user_selection < port_id :
			seatrac_port_name = ports[ user_selection ].device
			break
print( "You selected {} as the SeaTrac serial port".format(seatrac_port_name) )
# Open the serial port
seatrac_port = serial.Serial( seatrac_port_name, SEATRAC_BPS, timeout=5)
# GPS serial port setup
if USE_SERIAL_GPS:
	while True:
		user_selection = input("\r\nSelect GPS serial port: ")
				gps_port_name = ports[ user_selection ].device
				break
	print( "You selected {} as the GPS serial port".format(seatrac_port_name) )
	gps_port = serial.Serial( gps_port_name, 4800, timeout=5)
# SeaTrac response processing functions
# Checksum function setup
crc16 = crcmod.mkCrcFun(poly = 0x18005, initCrc = 0, rev = True, xorOut = 0 )
def process_seatrac(r) :
	global gps_swiss, rov_depth, rov_swiss, rov_wgs84
	# Extract checksum
	csum_bytes = bytearray.fromhex( response[-4:] )
	csum = csum_bytes[0] + 256 * csum_bytes[1]
	# Compute checksum
	csum_computed = crc16( bytearray.fromhex( response[1:-4] ) )
	if ( csum == csum_computed ) :
		# Extract command ID and command response
		cid = response[1:3]
		cresp = bytearray.fromhex( response[3:-4] )
		# Process position response (CID_PING_RESP)
		if ( cid == '42' ) :
			# Position is valid (bit 2 of FLAGS)
			if ( cresp[2] & 0b0100 ) :
				# Extract position in meters
				easting = int.from_bytes( cresp[-6:-4], byteorder='little', signed='True') / 10
				northing = int.from_bytes( cresp[-4:-2], byteorder='little', signed='True') / 10
				depth = int.from_bytes( cresp[-2:], byteorder='little', signed='True') / 10
				# Compute the absolute position
				rov_swiss['x'] = gps_swiss['x'] + easting
				rov_swiss['y'] = gps_swiss['y'] + northing
				rov_depth = depth
				# Convert to WGS84 datum
				rov_wgs84['lat'], rov_wgs84['lon'], __ = wgs84_ch1903.GPSConverter().LV03toWGS84(rov_swiss['x'], rov_swiss['y'], 0)
# YachtDevices GPS connection setup
if not USE_SERIAL_GPS:
	# Connect to the Yacht Devices server
	# AF_INET means ipv4, SOCK_STREAM means TCP
	gps_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
	gps_socket.connect((GPS_IP, GPS_PORT))
# GPS processing functions
# GPS data interpreter
streamreader = pynmea2.NMEAStreamReader()
def process_gps(data) :
	global gps_wgs84, gps_swiss, gps_lastfix
	for msg in streamreader.next(data):
		# Only consider the RMC NMEA sentence
		if msg.sentence_type == 'RMC' :
			# msg.lat/lon format: 4627.6999 = 46°27.6999'
			lat_deg = int( float(msg.lat) / 100 )
			gps_wgs84['lat'] = ( float(msg.lat) / 100 - lat_deg ) * 100 / 60 + lat_deg
			lon_deg = int( float(msg.lon) / 100 )
			gps_wgs84['lon'] = ( float(msg.lon) / 100 - lon_deg) * 100 / 60 + lon_deg
			# Convert the GPS coordinates into CH1903 Swiss coordinates
			gps_swiss['x'], gps_swiss['y'], __ = wgs84_ch1903.GPSConverter().WGS84toLV03(gps_wgs84['lat'], gps_wgs84['lon'], 0)
			# Update time of last fix
			gps_lastfix = str(msg.datestamp) + " " + str(msg.timestamp)[:8]
# ROV connection setup
# UDP socket
rov_socket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
# Main loop
with open(csv_filename, 'w', newline='') as csvfile:
	csv_writer = csv.writer( csvfile, delimiter=';', quotechar='"', quoting=csv.QUOTE_MINIMAL )
	# Column titles
	csv_writer.writerow( [ "PC time", "Base CH1903 X", "Base CH1903 Y", "ROV CH1903 X", "ROV CH1903 Y", "ROV depth", "Last fix GPS time" ] )
	# Store the last ping time to only send commands to SeaTrac every x seconds
	last_ping = 0
	# Store the last udp message to ROV time to only update every x seconds
	last_rov_update = 0
	while True:
		try:
			# Check for which devices data is available. If no data is available, timeout is 5s.
			if USE_SERIAL_GPS :
				ready_to_read, ready_to_write, __ = select.select([gps_port, seatrac_port], [rov_socket], [], 5)
			else:
				ready_to_read, ready_to_write, __ = select.select([gps_socket, seatrac_port], [rov_socket], [], 5)
			# Send a PING every x seconds
			if ( ( time.time() - last_ping ) >= SEATRAC_PING_SECONDS ) :
				# Ping beacon #3
				seatrac_port.write(b'#4003068126\r\n')
				# Reset stopwatch
				last_ping = time.time()
			# Read data from the SeaTrac and write to CSV
			if seatrac_port in ready_to_read :
				response = seatrac_port.read_until(b'\r\n').decode('ascii')
				start_pos = response.find('$')
				if ( start_pos >= 0 ) :
					# Start at $ and remove trailing \r\n
					response = response[start_pos:-2]
					process_seatrac( response )
					# Write to CSV
					date_str = datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S")
					gps_swiss_str = { 'x' : "%.1f" %gps_swiss['x'], 'y' : "%.1f" %gps_swiss['y'] }
					rov_swiss_str = { 'x' : "%.1f" %rov_swiss['x'], 'y' : "%.1f" %rov_swiss['y'] }
					rov_depth_str = "%.1f" %rov_depth
					# Columns:           [ "PC time", "Base CH1903 X",    "Base CH1903 Y",    "ROV CH1903 X",     "ROV CH1903 Y",     "ROV depth",   "Last fix GPS time" ]
					csv_writer.writerow( [  date_str,  gps_swiss_str['x'], gps_swiss_str['y'], rov_swiss_str['x'], rov_swiss_str['y'], rov_depth_str, gps_lastfix ] )
			# Read data from the GPS
			if USE_SERIAL_GPS:
				if gps_port in ready_to_read :
					try:
						data = gps_port.read().decode('ascii')
						process_gps(data)
					except:
						print("GPS decoding error")
						# Try to switch it to NMEA mode in case it is in binary mode
						gps_port.write(b'A0A200188102010100010101050101010001000100000001000012C00165B0B3')
			else:
				if gps_socket in ready_to_read :
					data = gps_socket.recv(BUFFER_SIZE).decode('ascii')
					process_gps(data)
			# Send position to ROV every x seconds
			if ( rov_socket in ready_to_write ) and ( ( time.time() - last_rov_update ) >= ROV_UPDATE_SECONDS ) :
				# Build GGA NMEA sentence
				lat_deg = int( rov_wgs84['lat'] )
				lat = 100 * lat_deg + ( rov_wgs84['lat'] - lat_deg ) * 60
				lon_deg = int( rov_wgs84['lon'] )
				lon = 100 * lon_deg + ( rov_wgs84['lon'] - lon_deg ) * 60
				#                                             time                                 lat               lon              fix  sats  hdop   alt     height          dgps
				msg = pynmea2.GGA('GP', 'GGA', ( datetime.datetime.utcnow().strftime("%H%M%S"),    str(lat) , 'N',        str(lon), 'E', '1', '08', '1.5', '0', 'M', '0', 'M', '', '0000'))
				# Send the sentence to the ROV
				rov_socket.sendto( bytes( str(msg) + '\r\n' , "ascii"), (ROV_IP, ROV_PORT) )
				print(str(msg))
				# Reset stopwatch
				last_rov_update = time.time()
		except KeyboardInterrupt:
			# Exit on Ctrl-C
			break
# Close the ports
seatrac_port.close()
gps_socket.close()
gps_port.close()
I’ve only tested it in the office for now, hope I can try it in the lake soon…
And if someone knows how to display the position of the base station (boat) on QGroundControl, I’d be very interested. (for now only the ROV position is displayed)
Hope that bits of this script can help someone !
So wonderful!
A hint to perhaps simplify the setup (not that there’s anything wrong with it). Most usbl are capable of a NMEA output mode, sending NMEA sentences on the serial port. Then you can just use a program like the Arundale nmea router to bridge the communication serial<->rov udp port.
Re, the usb gps and boat position, look on the General Settings page of QGC, you will see a selection for nmea gps port and baudrate selection. Set that up, and the boat position will be displayed.
Thanks !
I first tried with NMEA Router, but this implies using the USBL Windows software which is quite buggy (parameters not stored between launches, sometimes needs a reboot to work etc.).
Thanks for the boat position setting, I just tried it but QGroundcontrol crashes (segmentation fault) when selecting the serial port (/dev/ttyUSB0). Afterwards, it crashes every time I try to launch it (must remove the AutoconnectNmeaPort line in ~/.config/QGroundControl.org/QGroundControl.ini so it can launch again). I’m not running the Python script when it happens. Do you have a clue what might be wrong? I’m running QGroundControl v3.2.4-BlueRobotics-Rev6.
What a pro!
Can you try in a terminal screen /dev/ttyUSB0 9600 or whatever baudrate the gps uses? Does the gps show any output on the terminal?
It might be a multiple access thing, make sure no other programs are using the gps. If this is not an option, you might be interested in this feature, and you can send it from your python script on UDP (after it is merged): https://github.com/mavlink/qgroundcontrol/pull/7087
NMEA data is displayed correctly using screen, but QGroundcontrol still crashes.
I’m looking forward for the new feature, it’ll be much easier for my setup, and the NMEA on the boat wifi also has heading information which is very welcome !
Tell me if I can do something to help with the segfault.
Can you launch QGroundControl from a terminal and put the output + segfault in a pastebin?
Please go to console->set logging and enable the categories for linkmanager, and positionmanager.
I couldn’t find the category for positionmanager in the list, I tried adding PositionManagerLog=true in QGroundControl.ini, not sure if it helped.
Anyway here is the pastebin, hope it is useful ! https://pastebin.com/ijychsBg
I’m running QGroundControl.AppImage, maybe it behaves differently than when not packaged as AppImage ?
I also tried running it with gdb (never done that, not sure it makes sense). Output is here.
(I won’t be working until mid-January, don’t be surprised if I do not reply until then)
Hi Benji,
I have asked a question on how to mechanically integrate the seatrac X110 onto the BlueROV2 within this more general discussion: Blueprint Subsea Seatrac USBL Interface - #10 by Eloi
If you had a chance to contribute that would be great.
Thanks for the log Benji, it’s not clear still what the problem is, something with setting 4800 baudrate on the port maybe?
How are you getting along now?
Hi @jwalser, the current version of QGroundControl works well for me, I’m using UDP now and can display the ROV and the boat positions on the map. Great !
I’m looking into integrating a SeaTrac USBL with our setup, and running into issues with reading NMEA sentences into QGC. Using NMEA Router, I am sending the NMEA sentences from the GPS to the ROV UDP port, but do not see any coordinates in QGC.
Does this process only work with the Raspberry Pi on the ROV, or is it possible to send the NMEA sentences to the Pixhawk?
Hi @whalearg, welcome to the forum :slight_smile:
I haven’t used our NMEA routing before, so have brought this up internally with our software team to get a more complete response.
In the meantime, our GPS positioning documentation suggests checking the data is correctly being received in the ROV by looking at the nmearx screen session in the Raspberry Pi terminal (you can use the companion’s terminal over browser, or a standard ssh connection). Have you tried that? :slight_smile:
Those docs also mention that if the NMEA messages are forwarded to the ROV at UDP:27000 it will be automatically used by the ROV (which I assume should then show up in QGC). I assume that’s what you’re trying to do here?
Note also the information about
The positioning system must report the number of satellites, and the satellites must be greater than 6 for the autopilot to accept the position as a valid lock. When a valid position and lock is detected by the autopilot, the main LED on the autopilot will change from blue to green.
Hi Amy, I think these devices are usually integrated via companion, but Ardusub should also detect them as a GPS is plugged directly to the Pixhawk’s GPS port and properly set up. But as @EliotBR suggested, they need to pretend to be a GPS system.
Companion accepts GGA, RMC, GLL, and GNS messages.
ArduPilot, with GPS_TYPE = NMEA, takes these messages:
        _GPS_SENTENCE_RMC = 32,
        _GPS_SENTENCE_GGA = 64,
        _GPS_SENTENCE_VTG = 96,
        _GPS_SENTENCE_HDT = 128,
        _GPS_SENTENCE_PHD = 138, // extension for AllyStar GPS modules
        _GPS_SENTENCE_THS = 160, // True heading with quality indicator, available on Trimble MB-Two
        _GPS_SENTENCE_OTHER = 0
Hi Eliot and Willian, thanks for your responses. I should probably clarify. Our vehicle is currently set up as an AUV, so it doesn’t have a Raspberry Pi in it. With a GPS plugged directly into the Pixhawk’s GPS port, I’m able to see its position when it is surfaced (but of course, everything gets cut off when it goes underwater).
I’m currently trying to redevelop the vehicle to read in positional information from a SeaTrac USBL system. As a first step, I’m just plugging in the SeaTrac GPS receiver from the SeaTrac system into the topside PC, to convey lat/long to QGC via UDP NMEA sentences. I /think/ the reason this isn’t working is because I’m sending the NMEA data to 192.168.2.2:27000, which is the port a raspberry pi (if it’s in the system) would be listening to, but since there isn’t one, the lat/long data doesn’t go anywhere. I was wondering if there is a different way to send it directly to the Pixhawk, or alternatively, is there a different address to send it to so that it just goes to the PC running QGC (for instance, how would you get a topside GPS to show up in QGC?)
I’m not familiar with the SeaTrac USBL system. Does it only have ethernet setup? Then there’s no good way to get it to the Pixhawk.
You can get it to the topside computer, though. QGC can take NMEA strings via udp port 14401 to show the position of the topside computer in the map. It is not really the same, but I guess it is better than nothing.
Hi benji,
im trying do display my ROV and boat position on QGC with the seatrac X010 with no luck, i will really appreciate if you can tell me the steps in order to get the position on the QGC map and the coordinates.
thanks you in advanced and sorry for the throwback to a post from 2019
bump to this, also interested
Hi All,
Here is a little up on what we did to get Seatrac USBL ROV position onto QGC map. As we struggle a little bit thi might help as no coding needed.
First, need to configure an NMEA output on Pinpoint:
Important is to set UDP adress to ROV IP (here 192.168.2.2) and UCP to 27000
The go to BlueOS interface to use the NMEA Injector. Set as follow:
Then start the tracking on PinPoint, and only then open QGC.
Be carrefull opening QGC before starting the tracking does not work (at least for us!)
Then into QGC go to “Application settings” and change “AutoConnect to the following devices”, “NMEA GPS Device” to UDP Port and port 52120 as to be filled up.
A nice little BR2 should pop-up as soon as the USBL beacon is detected!
You can then display Lat/Long onto QGC overlay
Hope this help!
Fly safe Gents!
Hi, thanks for the guide.
I tried it out yesterday, but it seems to be some comms issues when running Pinpoint and QGC at the same time. I got it pinging and got the ROV position in pinpoint for some seconds, but then it seems to drop out.
I did everything just as shown in the guide above, but i was also not able to get the lat/long coordinates to show in QGC.
Hi @Jhans -
What version of QGC were you using?
