Hi @elhedody -
A 4 inch enclosure won’t fit under the existing electronics enclosure with the standard BlueROV2 frame. You can easily determine this from the provided CAD models of the unit. The side panels would need to be taller to move the bottom plate down! It seems you may be forking the frame design and modifying it after all!
