Can i put a 4” Series Enclosure at the place of Battery Tube (3" Series Enclosure) ? There are space for that with a clamp for 4" Series?
Best regards,
Frederico Vaz
Best regards,
Frederico Vaz
Hi Frederico,
There is not quite enough space for a 4" Series Enclosure where the battery enclosure is. If you need to mount an extra 4" Series Enclosure to a BlueROV2, we have a payload skid that supports that.
Also, you could mount it underneath the bottom panel. The bolt pattern for 3" clamps and 4" clamps is the same. I don’t know how well this would work and I don’t think I have ever seen it done, but it is possible.
Best,
Jonathan
Hello, I used the plans from Blue Robotics and just got someone to stretch it upwards, all the holes lined up perfect, I bought all the other parts needed from Blue Robotics.
I had already purchased the two 4" tubes earlier for a PVC frame and didn’t want to have to buy a 3" tube as well. The 4" tube is big enough for two 10,000 mAh 4s batteries.
I posted a photo of my earlier build on this forum somewhere.
The place that did it for me used CNC
