I purchased a new set of Navigator Flight Controllers to assemble BlueROV.However, when I used the attached firmware, I found that there was no video screen. After I rewrote the latest BlueOS firmware, the video screen appeared, but I could not connect the video again after using it for several times. What might be the reason?The QGC versions used are 3.5.6,4.0.1,4.2.2 and 4.2.3.
Hi @sharf, welcome to the forum ![]()
Sorry to hear you’re having camera issues. A couple of questions:
- Are you able to see the camera listed on the Video page?
- If not there may be some issue with the camera, in which case I’d recommend you contact support@bluerobotics.com to sort out a potential replacement / refund
- If so, is it set up with a stream?
- If not then you can try resetting the BlueOS video parameters as described in the documentation, or you can configure the stream manually
Thanks for your reply and I have solved it. This is because I didn’t set up the video stream properly.
