I am trying to get qgroundController to connect with the vehicle but it doesn’t connect. I really appreciate your help. I am trying to have this working for a long time and I cannot : (
I am using mac Sierra version 10.12.6
So the hardware is the one from BlueRov v1, but just reconfigured the motors position like BlueRov 2
I downloaded the new version of QgroundController and new raspberrypi image from here:
I use an a USB to Ethernet adaptor. I did all the network configuration mentioned here: BlueROV2 Software Setup.
I entered 192.168.2.1 for the IP Address and 255.255.255.0 (yes not 255.255.0.0)
I turn off the firewall.
I can ssh to raspberry pi, works perfect
I can see the video, works perfect
I cannot connect to the vehicle. Only If I use the usb por connected to pixhawk and laptop, I can connect to the vehicle.
If I do
nc -ul 192.168.2.1 14550
I get:
nc: Can’t assign requested address
Yes I can ping it
PING 192.168.2.2 (192.168.2.2): 56 data bytes
64 bytes from 192.168.2.2: icmp_seq=0 ttl=64 time=2.449 ms
64 bytes from 192.168.2.2: icmp_seq=1 ttl=64 time=0.488 ms
64 bytes from 192.168.2.2: icmp_seq=2 ttl=64 time=0.449 ms
64 bytes from 192.168.2.2: icmp_seq=3 ttl=64 time=0.469 ms
64 bytes from 192.168.2.2: icmp_seq=4 ttl=64 time=0.502 ms
3)firewall is turned off, and static ip is 192.168.2.1 per instructions I mentioned before.
Ethernet jack activity is working, blinking green.
screen -r mavproxy
There is no screen to be resumed matching mavproxy.
Then I restart mavproxy
pi@raspberrypi:~ $ ~/companion/scripts/start_mavproxy_telem_splitter.sh
Connect /dev/serial/by-id/usb-3D_Robotics_PX4_FMU_v2.x_0-if00,115200 source_system=200
Failed to connect to /dev/serial/by-id/usb-3D_Robotics_PX4_FMU_v2.x_0-if00,115200 : [Errno 2] could not open port /dev/serial/by-id/usb-3D_Robotics_PX4_FMU_v2.x_0-if00: [Errno 2] No such file or directory: ‘/dev/serial/by-id/usb-3D_Robotics_PX4_FMU_v2.x_0-if00’
The cable is connected from pin 4 and pin 5 from raspberry to the usb on the top of pikhawk (not the micro usb of the pikhawk)
However, how should the pikhawk be connected to raspberry? from the micro usb port on the side of the pikhawk to an usb port on the raspberry or the micro usb port of the raspberry.
If I connect from the micro usb pikhawk (on the side) to the big usb on the raspberry (not the micro) it works. Is this config correct ?
(I then power the raspberry from to the micro usb, because I run out of battery, is it ok to use it this way for testing?).
