I have set up ubuntu into VMWare and installed qgroundcontol. Now I plugged pixhawk via USB and would like to start firmware upgrade. Firmware menu appears for 1 second, then I get an error:
Found device: PX4 FMU V2
Error: Open failed on port /dev/ttyACM0: Permission denied
Upgrade cancelled
If upgrade failed, make sure to connect directly to a powered USB port on your computer, not through a USB hub. Also make sure you are only powered via USB not battery.
Upgrade cancelled
Any recommendation?
Thanx
