Did you check my thread? Here is the link. I also got this problem after the retrofit tutorial and I think I might had before as well, in the last time I tested with the old companion. Did you try to reduce the resolution? Please check if you had a similar problem with the camera after this. I put on the post a lot of possible fixes, none worked for me, but maybe they work for you.
