Hello, I am attempting to integrate an Arducam OV5647 picamera onto my Blue ROV 2’s. I have gotten this working on one of my vehicles with the following steps:
- plugged in the camera
- sudo raspi-config–>enable camera–>reboot
- sudo pip install picamera
- sudo killall raspivid (kills a script that runs at startup and interferes with my use of the camera)
- running this example script:
[code]import time
import picamera
with picamera.PiCamera() as camera:
camera.resolution = (1024, 768)
camera.start_preview()
Camera warm-up time
time.sleep(2)
camera.capture(‘foo.jpg’)[/code]
However, I have another, nearly identical vehicle, on which the camera is not working. There is no process “raspivid”, or “raspistill”, or anything like that, to kill. But when I try to run the example script, I get the following error:
mmal: mmal_vc_port_enable: failed to enable port vc.null_sink:in:0(OPQV): ENOSPC
mmal: mmal_port_enable: failed to enable connected port (vc.null_sink:in:0(OPQV))0xffa410 (ENOSPC)
mmal: mmal_connection_enable: output port couldn't be enabled
File "pi_camera_test.py", line 4, in <module>
File "/usr/local/lib/python2.7/dist-packages/picamera/camera.py", line 433, in __init__
self._init_preview()
File "/usr/local/lib/python2.7/dist-packages/picamera/camera.py", line 513, in _init_preview
self, self._camera.outputs[self.CAMERA_PREVIEW_PORT])
File "/usr/local/lib/python2.7/dist-packages/picamera/renderers.py", line 558, in __init__
self.renderer.inputs[0].connect(source).enable()
File "/usr/local/lib/python2.7/dist-packages/picamera/mmalobj.py", line 2212, in enable
prefix="Failed to enable connection")
File "/usr/local/lib/python2.7/dist-packages/picamera/exc.py", line 184, in mmal_check
raise PiCameraMMALError(status, prefix)
picamera.exc.PiCameraMMALError: Failed to enable connection: Out of resources
This is the same error I got on the original vehicle before killing the “raspivid” process. To make sure the camera is connected correctly, I have run:
vcgencmd get_camera
which returns: supported=1 detected=1
Both vehicles are running Raspbian 8.0, codename jessie. The only difference between them is I have removed the tether interface board on the first vehicle, the one on which the camera is working. So I figure that there must be some other process that has to do with the tether board that is tying up the camera on the tethered vehicle. Problem is, I can’t figure out what that process is.
I compared the results of ps -A on both vehicles, and found some processes that were different. Of those, the suspicious looking ones were: start_webui.sh, which apparently is some web interface for the pi camera, and mmal-vchiq, which has something to do with the camera, but I’m not sure what. However, I tried killing both these processes, to no avail.
Here is the output of my ps -A on the tethered vehicle (the one the camera isn’t working on):
[code]1 ? 00:00:02 systemd
2 ? 00:00:00 kthreadd
3 ? 00:00:00 rcu_gp
4 ? 00:00:00 rcu_par_gp
5 ? 00:00:00 kworker/0:0-cgr #
6 ? 00:00:00 kworker/0:0H-mm #
7 ? 00:00:00 kworker/u8:0-ev #
8 ? 00:00:00 mm_percpu_wq #
9 ? 00:00:00 ksoftirqd/0
10 ? 00:00:00 rcu_sched
11 ? 00:00:00 rcu_bh
12 ? 00:00:00 migration/0
13 ? 00:00:00 cpuhp/0
14 ? 00:00:00 cpuhp/1
15 ? 00:00:00 migration/1
16 ? 00:00:00 ksoftirqd/1
17 ? 00:00:00 kworker/1:0-eve #
18 ? 00:00:00 kworker/1:0H-kb #
19 ? 00:00:00 cpuhp/2
20 ? 00:00:00 migration/2
21 ? 00:00:00 ksoftirqd/2
22 ? 00:00:00 kworker/2:0-eve #
23 ? 00:00:00 kworker/2:0H-kb #
24 ? 00:00:00 cpuhp/3
25 ? 00:00:00 migration/3
26 ? 00:00:00 ksoftirqd/3
27 ? 00:00:00 kworker/3:0-cgr
28 ? 00:00:00 kworker/3:0H-kb
29 ? 00:00:00 kdevtmpfs
30 ? 00:00:00 netns
31 ? 00:00:00 kworker/0:1-eve
32 ? 00:00:00 kworker/1:1-cgr #
33 ? 00:00:00 kworker/2:1-pm #
34 ? 00:00:00 khungtaskd
35 ? 00:00:00 oom_reaper
36 ? 00:00:00 writeback
37 ? 00:00:00 kcompactd0
38 ? 00:00:00 crypto
39 ? 00:00:00 kblockd
40 ? 00:00:00 watchdogd
41 ? 00:00:00 rpciod
42 ? 00:00:00 kworker/u9:0-hc
43 ? 00:00:00 xprtiod
44 ? 00:00:00 kworker/u8:1-ev
46 ? 00:00:00 kswapd0
47 ? 00:00:00 nfsiod
58 ? 00:00:00 kthrotld
59 ? 00:00:00 kworker/3:1-cgr
60 ? 00:00:00 iscsi_eh
61 ? 00:00:00 dwc_otg
62 ? 00:00:00 DWC Notificatio
63 ? 00:00:00 vchiq-slot/0 #
64 ? 00:00:00 vchiq-recy/0 #
65 ? 00:00:00 vchiq-sync/0 #
66 ? 00:00:00 vchiq-keep/0 #
67 ? 00:00:00 SMIO
68 ? 00:00:00 kworker/2:2-eve
69 ? 00:00:00 irq/86-mmc1
70 ? 00:00:00 kworker/2:3-eve
71 ? 00:00:00 kworker/2:4-mm_
72 ? 00:00:00 mmc_complete #
73 ? 00:00:00 kworker/2:1H-kb
74 ? 00:00:00 kworker/0:1H-kb
75 ? 00:00:00 kworker/1:1H-kb
76 ? 00:00:00 kworker/1:2H
77 ? 00:00:00 jbd2/mmcblk0p2-
78 ? 00:00:00 ext4-rsv-conver
79 ? 00:00:00 kworker/0:2H-mm
80 ? 00:00:00 ipv6_addrconf
84 ? 00:00:00 kworker/3:1H-kb
87 ? 00:00:00 kworker/2:2H
94 ? 00:00:00 kworker/3:2H
105 ? 00:00:00 kworker/1:2-cgr
108 ? 00:00:00 kworker/u8:2-ev
122 ? 00:00:00 kworker/0:2-eve
126 ? 00:00:00 systemd-journal
130 ? 00:00:00 systemd-udevd
180 ? 00:00:00 SMIO
211 ? 00:00:00 mmal-vchiq
223 ? 00:00:00 mmal-vchiq
245 ? 00:00:00 cfg80211
251 ? 00:00:00 kworker/3:2-mm_
252 ? 00:00:00 brcmf_wq/mmc1:0
254 ? 00:00:00 brcmf_wdog/mmc1
273 ? 00:00:00 mmal-vchiq
274 ? 00:00:00 mmal-vchiq
276 ? 00:00:00 mmal-vchiq
406 ? 00:00:00 kworker/1:3-eve
407 ? 00:00:00 wpa_supplicant
481 ? 00:00:00 avahi-daemon
482 ? 00:00:00 cron
485 ? 00:00:00 inetd $
489 ? 00:00:00 rsyslogd
491 ? 00:00:00 dbus-daemon
509 ? 00:00:00 avahi-daemon
536 ? 00:00:00 systemd-logind
567 ? 00:00:00 thd
625 ? 00:00:00 kworker/u9:1-hc
626 ? 00:00:00 hciattach
627 ? 00:00:00 kworker/u9:2-hc
630 ? 00:00:00 bluetoothd
716 ? 00:00:00 dhcpcd
732 ? 00:00:00 ntpd
736 ? 00:00:00 sshd
740 ? 00:00:00 screen
745 pts/1 00:00:00 sh
747 pts/1 00:00:00 xargs
748 pts/1 00:01:02 mavproxy.py
772 ? 00:00:00 screen
774 pts/2 00:00:00 bash
776 pts/2 00:00:01 gst-launch-1.0
783 ? 00:00:00 screen
785 pts/3 00:00:00 start_webui.sh
794 ? 00:00:00 screen
796 pts/4 00:00:00 start_webtermin
804 ? 00:00:00 screen
806 pts/4 00:00:01 tty.js
807 pts/5 00:00:01 comm_router.py
830 ? 00:00:00 screen
832 pts/7 00:00:02 node
840 ? 00:00:00 screen
842 pts/8 00:00:00 nmea-receiver.p
850 ? 00:00:00 screen
852 pts/9 00:00:01 underwater-gps.
862 tty1 00:00:00 agetty
878 ? 00:00:00 ssh-agent
881 pts/3 00:00:05 node
882 pts/3 00:00:00 tee
1285 ? 00:00:00 kworker/u8:3-ev
1310 ? 00:00:00 sshd
1320 ? 00:00:00 systemd
1323 ? 00:00:00 (sd-pam)
1326 ? 00:00:00 sshd
1328 pts/0 00:00:00 bash
1450 pts/0 00:00:00 ps[/code]
Any ideas? Of course I could just start killing every process until the camera works, but I want to avoid breaking things if possible.
