Trouble accessing/ connecting to blueos.local for updates
I have followed all the set up steps and still cannot connect to 192.168.2.2] or blueos.local when I paste in the browser address bar.
Does anyone know how I solve this problem? I am working on a PC
I was able to eject and update raspberry pi, put it back in but still no luck connecting to blueos.local any pointers on how to troubleshoot this?
Hi @Mary-Claire,
Have you completed the network configuration? You won’t be able to connect without the interface to the vehicle being set to an IP address of 192.168.2.1, and there may be other issues related to fire walls.
Turned out to be a hardware problem. Problem solved.
I had blueOS up and running. But switched from RP3 to RP4 and downloaded BlueOS to a new SD card. No I cannot connect to the blueos with any of the PI’s inserted. I’m now trying to get the old RP3 (which was fully working) connected again.
Heres my ethernet connections:
enx00e04c3600d5: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.2.1 netmask 255.255.255.0 broadcast 192.168.2.255
inet6 fe80::e8bc:f61f:3c07:baf0 prefixlen 64 scopeid 0x20
ether 00:e0:4c:36:00:d5 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 223 bytes 24511 (24.5 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enx3448edb746dd: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 34:48:ed:b7:46:dd txqueuelen 1000 (Ethernet)
TX packets 0 bytes 0 (0.0 B)
And here’s my ping:
(base) stina@stina-XPS-13-7390:~$ ping 192.168.2.1
PING 192.168.2.1 (192.168.2.1) 56(84) bytes of data.
64 bytes from 192.168.2.1: icmp_seq=1 ttl=64 time=0.070 ms
64 bytes from 192.168.2.1: icmp_seq=2 ttl=64 time=0.072 ms
64 bytes from 192.168.2.1: icmp_seq=3 ttl=64 time=0.073 ms
64 bytes from 192.168.2.1: icmp_seq=4 ttl=64 time=0.073 ms
64 bytes from 192.168.2.1: icmp_seq=5 ttl=64 time=0.072 ms
64 bytes from 192.168.2.1: icmp_seq=6 ttl=64 time=0.074 ms
^C
— 192.168.2.1 ping statistics —
6 packets transmitted, 6 received, 0% packet loss, time 5104ms
rtt min/avg/max/mdev = 0.070/0.072/0.074/0.001 ms
This is what I type in my browser window: https://192.168.2.2/
This RP3 was working perfectly before. I’ve tried two different cables, they have both proven ok before. I’m running out of ideas.
Settings says I am connected to enx00e04c3600d5 with 100 Mb/s
What am I doing wrong?
Turned out to be a loose connection in hardware. Problem solved.
