We have been able to connect the boat with ethernet but when we try to run a wireless connection via raspberry pie it wont connect aka showing us the portal for controls and everything etc. We need this cause we are trying to put the boat in a body of water today
Hi @chrisredd42 -
Welcome to the forums!
If you can’t reach your BlueBoat via the BaseStation, you should verify all the connections in the chain from the Raspberry Pi to your computer.
- BaseStation WiFi network is available, and your computer is connected to it, with IP address set to 192.168.2.1 (this needs to be done if connecting via WiFi or USB-C to Ethernet adapter to box), subnet mask 255.255.255.0
- You can reach BaseStation Mikrotik at 192.168.2.3 in the browser
- You can reach BlueBoat Mikrotik at 192.168.2.4
- If the previous are all true, and the Raspberry Pi has finished starting up, you can reach BlueOS at 192.168.2.2
When you unplug your ethernet cable used for direct access from the Raspberry Pi, you need to plug the Mikrotik Radio back into it!
This is all detailed in the setup guide - please let us know where things were unclear that led to your issues!
