Can't connect to blue boat
Having replaced the board on the blue boat, I am now not able to connect to the boat and base station. Any suggestions?
I have a new BlueBoat. But I cannot connect the boat to my Windows computer via the base station. As a result, I am unable to access the BlueOS software via the web browser 192.168.2.2 and perform the further installation and sail with the BlueBoat
I performed the Basestation pairing and network setup according to the steps as stated on the BlueBoat software setup on the website.
I cannot access the Blueboat router via the web browser (192.168.2.4) or BaseStation to my computer via USB I cannot access the BaseStation’s router (192.168.2.3).
I also connected my computer to Raspberry Pi via an ethernet cable and the USB ethernet adapter (to check whether the Raspberry PI works). This way I can access the BlueOS software via the web browser 192.168.2.2.
It seems that the pairing of the base station router and the blueboat router is not successful.
Is there a way to reset the router to default settings? with a simple step by step guide
i did have a MikroTik-58FD17 Wi-Fi shown, but when i connected direct to the boat via ethernet it then was shown in winbox I followed the first step to remove configuration and then the programme froze and the Wi-Fi MikroTik-58FD17 disappeared please help to gain access
Hi @John59a -
It sounds like you’ve removed the default settings on your Mikrotik radios, and neither is allowing you to access them / they’r enot reaching each other. Once you get that resolved, BlueOS should load as it does with the ethernet cable.
This zip file has the materials and instructions you need! It’s great that you already have Winbox, which is used to configure each radio.
