QGC camera issues on ubuntu 22
Hi everyone,
Since I moved to the navigator I did not succeed to have the video return on QGC 4.4.0. I searched and tried for many possible solutions which I found on this forum but was unsuccessful in retrieving the video. I am using Ubuntu 22.04 and I am not able to get the video on QGC 4.4.0.
I get the following error in the console:
“VideoReceiverLog: GStreamer error: Failed to upload buffer”
I am able to succesfully stream the video using gstreamer:
gst-launch-1.0 -vc udpsrc port=5600 close-socket=false auto-multicast=true ! application/x-rtp, payload=96 ! rtph264depay ! decodebin3 ! fpsdisplaysink sync=false
Also I am able to stream the video on QGC in windows as well as if I check the return on blueos.local. So it seems to me that it is a problem with QGC on Ubuntu 22.04.
Has someone faced a similar issue? Any help would be really appreciated.
I specify that I have a Bluerov native USB camera plugged into the Raspberry Pi.
thank in advance,
best regards,
Caspers Bruno.
Hi @Kojack -
The recommended version of QGC is 4.2.8.
Have you followed the linux setup instructions?
Hi @tony-white
I have tried many QGC control version including the 4.2.8 (I retry it after your message) and none works.
and yes I followed thoses steps to install it!
Hi @Kojack -
Maybe this thread is relevant?
hi @tony-white ,
I forgot this steap in my first message ! Sorry
When I install with the first linux tutorial you sent me I have the error I told you:
and this command doesn’t work (founded here Video streaming is not working on Linux PC - Blue Robotics Software / QGroundControl - Blue Robotics Community Forums):
It open gst-launch but I only have a black screen.
Then I tried the command,
sudo apt remove gstreamer1.0-vaapi
After that I have the video in gstreamer, but still not in QGC. But the error message change, I have now:
"VideoReceiverLog: GStreamer error: Your GStreamer installation is missing a plug-in.
Hey @Kojack,
did you solve this problem?
I’m running in the same error. Can you help me to get out of it?
The problem was solved here.
