PSM Power Sense Module voltage alarm?
Does anyone know if it is possible to set an alarm when using the PSM? I would like to be able to set a certain voltage so that I get some kind of pop up or flashing display on my computer when my batteries start to become depleted.
Hi @SweUSV -
Yes, this is possible. Checkout the failsafes page under Vehicle Setup, Configure, Failsafes. You can set notifications for low and critical battery voltages.
Found this in the Blue Boat manual and thought I would add this in case anyone else needs it.
Hi @SweUSV -
Good find. This is also found (in less detail) on the failsafes page - maybe you didn’t scroll down?
Thanks Tony. I saw this but the action tab doesn’t say anything about the flashing message and buzzer which is what I was looking for.
Thanks for mentioning this - I’ve raised an Issue to recommend some ways we could improve the interface (and potentially provide other tools) to help avoid similar problems in future :slight_smile:
